Oil in AC system
120,000 MILES
RONSMERC
Have replaced AC expansion valve, condenser and receiver/dryer. How much oil should I add when recharging the system? Mercedes Benz specify 7.5 oz as a total for the system.
Dec 12, 2018 at 5:19 AM
Good evening,
I attached a chart below for you to view. the big thing is that it depends on the type and make of your compressor.
The oil in the Freon side is only 20cc. The other oil only goes into the compressor itself. It cannot be added to the Freon system. it has to be added directly to the compressor.
Fluid Types
Compressor Oils
Pag Oil
Caltex Capella WF 100
Capella WF 100
Shell Clavus 0el G 100
Suniso 5 GS
Ester oil
For Bock/Bitzer air conditioning refrigerant compressors
MB 362.0 compressor oil A 001 989 08 03
Capacities
York A/C compressor, Engine 110
Oil level quantity
Min .................... 180 cc
Normal .................... 240 cc
Max .................... 300 cc
Delco A/C compressor, Engines 116 and 117
Oil level quantity .................... 300 cc
Delco A/C compressor, Engine 617.951
Fresh oil in compressor .................... 170 cc
When replacing compressor, drain oil from old compressor and measure quantity.
If more then 40 cc, replace with same amount from old compressor.
If less then 40 cc, add 90 cc to quantity measured from old compressor to new compressor.
Renew condenser .................... 50 cc
Renew evaporator .................... 70 cc
Renew receiver dehydrator .................... 40 cc
Nippondenso A/C compressor
Initial oil fill .................... 120 cc
Renew compressor, drain old compressor and new compressor, add same quantity to new compressor.
Renew condenser .................... 20 cc
Renew evaporator .................... 40 cc
Renew dryer .................... 10 cc
Vacuum line from evaporator to compressor .................... 10 cc
pressure line from compressor to condenser .................... 10 cc
Dec 12, 2018 at 8:40 AM
