Oil gauge reads zero
29,000 MILES
THWEATT
Oil gauge reads zero replaced oil sensor.
Jun 21, 2019 at 8:20 PM
Good morning,
I would start by installing a manual gauge into the sender hole and make sure it is correct.
https://www.2carpros.com/articles/high-or-low-engine-oil-pressure
If there is no pressure, there are possibilities.
1. low oil level.
2. clogged pick up screen.
3. Failed oil pump.
4. Main or rod bearing failure.
All these will need to be checked if you have no oil pressure.
Jun 21, 2019 at 9:51 PM
