Where is the oil filter located?
111,549 MILES • V6 • 2WD • AUTOMATIC
JESTER620
Where is the oil filter located on the car listed above LS?
May 24, 2023 at 6:49 AM
BRENDON S
  • 653 POSTS
Hello JESTER620,
If you locate your A/C Compressor it will be right behind it on the side of the motor. There is an access panel under the radiator held on by 2 nuts. If you remove this access panel and look up at the side of the motor, you will be able to see it between the A/C Compressor and Starter.
I have added a couple pics for your reference.
May 24, 2023 at 8:40 PM
JESTER620
Thank you very much.
May 24, 2023 at 8:49 PM
BRENDON S
  • 653 POSTS
Hello JESTER620,
No problem. Happy to help. In case you need it, fluid capacity for the oil is 4.5 quarts 5w30.
Thank you,
Brendon
May 24, 2023 at 9:57 PM
