Im trying to fix a Gasket that leaks
it goes between the oil pump adapter housing , and the block
my issue is that ive tried referencing from online forums , but i cant seem to peel it apart far enough to get the gasket out
everyone said there is 3 bolts holding it
ive found the one behind the crank pulley and loosened it ( 12mm )
one slightly above and to the left
( 10 mm )
and another above and to the left of that one , ( 12mm )
now i've loosened them all and i cant get any clearance to pick the gasket out
so i believe that i loosened the wrong bolts
does anyone have a diagram they can send me
i would really appreciate it . .
im attempting to tackle this again tomorrow
( 10 mm )
Jul 28, 2017 at 9:08 PM
