Oil filler neck
30,000 MILES • 6 CYL • AWD • AUTOMATIC
HANSENISAAC
Just broke the oil filler neck on my SUV. Can I just screw the cap on without the neck as it does for, or is there a purpose for the oil filler neck?
Aug 2, 2017 at 10:24 AM
CARADIODOC
  • 34,415 POSTS
When there is a pipe about eight to ten inches long, that is for better access when pouring in the oil. You should see that it attaches the same way the "oil" cap attaches. To say that a different way, the cap will screw on in place of the extension pipe. Just use a funnel the next time you add oil. If you go to one of the speedy lube places, they usually pump from a bulk oil tank through a really long nozzle that can reach the hard-to-reach fill ports.
Aug 2, 2017 at 11:58 AM
