Oil drain plug came out after oil change
24,000 MILES • 3.7L • V6 • 4WD • AUTOMATIC
SUBLIME30
  • 8 POSTS
The drain plug somehow came out right after the oil change. The car was driven 2 miles and shut off. I replaced the plug and put new oil back in. Is the engine ruined or is there any way I can get it to work for about the next two weeks until I can afford a new engine so I can get back and forth to work?
Jul 28, 2019 at 6:00 AM
Good afternoon,
Does the engine turn?
If it does, will it start?
If it does not, then no, you need the engine replaced now.
Can you send me a video of the engine when you try to start it?
Jul 28, 2019 at 6:05 AM
SUBLIME30
  • 8 POSTS
Yes, give me one second.
Jul 28, 2019 at 6:22 AM
Okay.
Jul 28, 2019 at 6:33 AM
SUBLIME30
  • 8 POSTS
Here is the video:
Jul 28, 2019 at 6:48 AM
SUBLIME30
  • 8 POSTS
Did you get the video?
Jul 28, 2019 at 6:52 AM
Thanks. It sounds like the main bearings are locked up.
No way to get any more time out of it.
Jul 28, 2019 at 6:59 AM
SUBLIME30
  • 8 POSTS
If that is it can change them myself?
Jul 28, 2019 at 7:19 AM
SUBLIME30
  • 8 POSTS
And do you think the main bearings being locked up is it?
You need to replace the entire engine.
Do you have a lift, engine crane and all the tools to replace the engine?
Jul 28, 2019 at 7:23 AM
SUBLIME30
  • 8 POSTS
No, but I know a mechanic.
Jul 28, 2019 at 8:29 AM
Okay, then he/she should know what to do.
I would look for a good used motor. That would keep the cost down for you.
Jul 28, 2019 at 8:38 AM
SUBLIME30
  • 8 POSTS
Thank you
Jul 28, 2019 at 11:22 AM
You are welcome
Always glad to help
Jul 28, 2019 at 3:33 PM
