Oil dipstick looks dull grey at bottom
2019 KIA OPTIMA
5 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
J.T.70
  • 28 POSTS
I was looking at the car listed above and pulled the oil dipstick. It looked shiny silver most of the length but about the bottom 6 inches was a dull grey, as if it had been dipped in acid. This grey area was at least twice as high from the tip as the full point for the oil. At first I thought I was looking at milky oil but the oil was clean (now). They said this long dull grey satin color area near the bottom was supposed to make it easier to see the clean oil. There were no markings on the dipstick except for 2 dimples with no labels, no crosshatch. I have a lot of trouble believing this is normal. i think someone messed up the oil or there was a leak of other fluid into it which they are not telling me about. The service manager could not understand what I meant by "this upper part is shiny and the bottom is dull." As if every dipstick he ever saw was dull grey at the bottom. Has anyone ever seen this? I haven't had a chance to examine other Kia cars yet.
Jan 19, 2020 at 1:46 PM
  • CAR REPAIR CONTRIBUTOR
Good afternoon,
Can you upload a picture of the dipstick?
It sounds normal for easier reading of the fluid level. They have been doing this for a couple of years.
Jan 19, 2020 at 1:52 PM
J.T.70
  • 28 POSTS
The car is at the dealer, it's not mine. I didn't take a photo. I searched Google and the closest I could find was photos which were of dipsticks with varnish from overheated oil and dipsticks from engines which were grossly overfilled.
Jan 19, 2020 at 1:57 PM
J.T.70
  • 28 POSTS
It seemed to actually make it harder to read the oil level with no crosshatch. I thought I wasn't seeing through some very milky oil but the oil was clean (now).
Jan 19, 2020 at 1:59 PM
Okay, I understand.
It is normal again for this. If you are not sure, go back and have them check another 2019 and see if it has the same stick. It most likely will have the same stick.
Jan 19, 2020 at 2:03 PM
J.T.70
  • 28 POSTS
I plan to check other cars. Thanks.
Jan 19, 2020 at 2:08 PM
You are welcome.
Always glad to help.
Jan 19, 2020 at 2:11 PM
