Oil dip stick is full of oil when checking level
2001 NISSAN MAXIMA
178,000 MILES • 6 CYL • 2WD • AUTOMATIC
ROYCAR71
  • 359 POSTS
I did an oil change and put 4 quarts of 5w30. Initially when I checked oil after change, oil level was around hash mark area. Then when i started car and looked again. Oil level was all the way up to handle of dip stick and instead clean clear color of oil it was dark brown. Is this a sign oil is mixing with coolant?
PS: car has a hard time starting and staying on when starting.
Feb 17, 2020 at 2:51 AM
Good afternoon,
It could be. Did you have an overheating issue prior to the oil change?
https://www.2carpros.com/articles/coolantantifreeze-in-the-engine-oil
How did the oil look when you drained the old oil out?
Can you post a picture of the oil fill port with the cap off?
Feb 17, 2020 at 3:07 AM
ROYCAR71
  • 359 POSTS
Sorry the car belonged to a relative and i didn't take pic. The oil was black and thick and sludge. As for overheating, no, she complained of hard steering and car ac blowing hard when accelerating.
Feb 17, 2020 at 7:50 AM
Black sludge is bad. That is neglect from not changing the oil.
Chances are there is internal engine damage.
Feb 17, 2020 at 7:54 AM
