differential gear oil change
33,000 MILES • 5.3L • V8 • 4WD • MANUAL
AJS2013
how often do you recommend to change differential oil? It is not mention in owner's manual of GM cars.
Sep 15, 2017 at 12:48 PM
CARADIODOC
  • 34,406 POSTS
This video will show you how to service the differential
https://youtu.be/6F26Kir0OCg
Typically it does not have a specified mileage interval, and as with power steering fluid, you leave it alone until service is required. There are some GM vehicles that have an odd differential design that is prone to developing problems, and changing the gear lube reduces the number of failures. Those are spelled out in the owner's manual, and I suspect it will be listed on the cards the dealers send out to pull you in for those maintenance services. GM has a history of selling vehicles with new designs that are still under test and evaluation, but they let the unsuspecting owners do the testing. As with their rear-steer truck disaster, I think this new differential design will go away too. If you think you might have this on your truck, visit the dealer's parts department and they can search your vehicle's build data from GM and tell you which axle you have. If you have the more trouble-free design that has been around forever, regular gear lube changes are not needed, but if you have a locking differential with internal clutch plates, when you do have to replace the lube, you'll need to add a small bottle of whale oil additive to prevent chattering when you go around slow-speed corners.
Sep 15, 2017 at 1:01 PM
AJS2013
Thanks for your attention, the video was great!
Sep 15, 2017 at 2:55 PM
JLOVE1234
The gear teeth are broken off on the differential.
I was told I need a rear end. Most salvage yards are selling this unit for $500-$600 but they are only giving me 30 days worth of warranty. What kind of lifespan can I expect from this used part.
Feb 25, 2021 at 2:14 AM (Merged)
  • 31,937 POSTS
Hard to say, but 30 days is just enough to know if there is a problem now, if you get it, check the oil for metal, change any oil in it and listen for any noise at speed, faulty diff's will alter pitch with throttle settings, back off the throttle and the noise will alter, ther is no way of knowing what life you will get.
mark (mhpautos)
MR.HORNE79
Do I need to put a magnet on an aluminum rear differential cover or can I use a drain plug magnet?
Feb 25, 2021 at 2:16 AM (Merged)
CARADIODOC
  • 34,406 POSTS
Any magnet is fine. It's job is to collect the tiny particles that break off, mainly from limited-slip clutch plates. You don't want that collecting in the bearings. You'll find the metal appears as a growth of fuzzy grease on the magnet.
If you have anti-lock brakes with a speed sensor on top of the differential housing, those will collect metal filings too, and when bad enough, that will prevent it from generating a speed signal. You don't have to replace the sensor for that. Removing and cleaning it is all that's needed.
