Oil dash light keeps turning on and off
139,230 MILES • 1.4L • 4 CYL • 2WD • AUTOMATIC
MSOSO
Hi everyone, my car listed above has been recently overhauled, changed everything including oil pump and the oil pressure switch by the camshaft sensor. Every time i drive up a hill the oil light comes on dash beeps about 3 times then goes off. I don't what else to do because it's very disturbing. any suggestions on what else to do to fix the problem?
Jun 25, 2020 at 12:52 PM
If this only happens going up an hill then I would think the oil level is low.
The only thing in an engine that knows you are on a hill is the oil as it moves back and forward in the oil pan. With that being the case, we need to start with checking the oil level and I would suggest adding oil until it is at the top of the full mark. Don't just put it in the proper range, we need to put it at the highest possible safe mark.
Here is a guide that in step 8 it covers how to check the oil. Let us know what you find. Thanks
https://www.2carpros.com/articles/how-to-change-engine-oil-and-filter
Jun 26, 2020 at 12:49 AM
