Oil cooler lines
200,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
DENESE HAROLD
The rubber hose on my oil cooler lines are leaking. My question is, can I cut the lines and replace just the hose or do I have to replace the whole line? Thanks!
Jul 8, 2017 at 1:03 PM
HARRY P
  • 2,292 POSTS
Personally, I have replaced the whole cooler line itself when it was leaking. However, I have seen people do what you are suggesting and they are not complaining. Just be sure that the clamps that use hose that can withstand the pressure and also make sure that the clamps that you use are very tight. Otherwise if it pops off while you are driving, you could have a serious issue. Those lines are under pressure and it would not take more than a few seconds for you to be out of oil.
Jul 8, 2017 at 1:10 PM
HARRY P
  • 2,292 POSTS
Also, the hoses that you buy would have to have a large enough diameter to fit over the old ones. Probably over an inch diameter.
Jul 8, 2017 at 1:13 PM
DENESE HAROLD
Thanks so much for your answer!
Jul 8, 2017 at 1:16 PM
  • 55,746 POSTS
HEYMAN1104 is one of our best!
Please use 2CarPros anytime, we are here to help. Tell a friend please.
Cheers, Ken
Jul 10, 2017 at 7:07 AM
