Oil cooler lines
200,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
CHEVYKINGG
Is it okay to delete oil cooler lines?
Apr 1, 2019 at 6:49 AM
STEVE W.
  • 15,421 POSTS
No. The lines are there because the oil in those vehicles tends to run hot because of the poor airflow. So they get the oil cooler to help. Eliminating them can raise the temperatures in the oil which can cause it to break down faster.
Apr 1, 2019 at 7:35 AM
I agree with Steve.
If you have an issue with the one in the radiator, you can add one externally to keep the temperature down.
Apr 1, 2019 at 9:00 AM
