oil cooler line/ lower radiator hose
170,000 MILES • 4.0L • V6 • 2WD • AUTOMATIC
NEWGUY3
I replaced the radiator and the lower hose needed changing I change it but I'm having trouble getting the oil cooler line on the shroud is on but the hose isn't on all the way do you have any suggestions on how to put it on without taking the shroud off?
Aug 25, 2014 at 3:45 AM
FREEMBA
  • 1,152 POSTS
If the shroud is loose, you should be able to move it over enough to allow room to put the hose on completely. (You'll have to remove all of the shroud bolts to get it loose enough)
Aug 25, 2014 at 4:44 AM
NEWGUY3
Thanks! Would that work for the oil cooler line on the bottom of the radiator? The difficulties with the line is when I get it to the radiator and place it there it doesn't turn
Aug 25, 2014 at 5:12 AM
FREEMBA
  • 1,152 POSTS
Be sure to have a little slack once you get the line to the radiator, if there is pressure pulling back on the line it will be difficult to screw it on. (You may have to move the radiator toward to line to connect it and then move it back in place.)
Aug 25, 2014 at 10:08 AM
NEWGUY3
Alright thanks again!
Aug 25, 2014 at 10:52 AM
