Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chrysler
Pacifica
Engine
Oil Cooler
Oil cooler housing bolt hole threads are stripped?
2004 CHRYSLER PACIFICA
190,000 MILES • 3.5L • V6 • 4WD • AUTOMATIC
JGRAY563
MEMBER
1 POST
The oil cooler housing that bolts up to the block. The bolt hole is stripped and I'm needing a solution.
Mar 9, 2023 at 10:58 AM
STEVE W.
Experienced Mechanic
About the only option would be to get a Heli-coil kit in the correct size and install it.
https://www.youtube.com/watch?v=NoIcq2pWxRc
Check out the images (below). Let us know if you need anything else.
Image (Click to enlarge)
Mar 9, 2023 at 3:58 PM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
