Oil cooler removal
500,000 MILES • 5.4L • V8 • 2WD • AUTOMATIC
JWP90000
  • 5 POSTS
How to remove cooler under oil filter?
Jul 30, 2020 at 8:52 PM
Good morning,
I attached the procedure and pictures for you.
The bolt that holds the cooler to the motor is the threaded bolt that holds the oil filter to the housing. Inside the bolt is a allen head that you remove to remove the cooler.
Oil Cooler
Removal
1. Raise and support the vehicle.
2. Remove the drain plug and drain the engine oil.
3. Drain the coolant.
4. NOTE: Make sure all O-ring seals are in place.
Remove the oil filter.
5. Slide the hose clamps down and disconnect the coolant hoses from the oil cooler.
6. Remove the oil cooler insert, and remove the oil cooler.
Jul 30, 2020 at 9:05 PM
JWP90000
  • 5 POSTS
do you know the allen size will hex socket work?
Jul 30, 2020 at 10:09 PM
The socket is a 14 mm allen head socket. You can get it at any parts store.
Jul 30, 2020 at 10:21 PM
JWP90000
  • 5 POSTS
Thank you very much.
Jul 30, 2020 at 11:28 PM
You are welcome.
Always glad to help.
Jul 30, 2020 at 11:30 PM
JWP90000
  • 5 POSTS
when replacing cooler does it make a difference on the 2 hoses to cooler hook up top or bottom?
Aug 4, 2020 at 5:57 AM
Either way is good. The coolant just circulates through the cooler.
Aug 4, 2020 at 6:01 AM
JWP90000
  • 5 POSTS
Aug 4, 2020 at 6:04 AM
You are welcome.
Aug 4, 2020 at 6:21 AM
