Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Cruze
Engine
Oil Cooler
Replace/Remove
When replacing the oil cooler, do I have to get a new gasket, or can I use RTV sealant?
2014 CHEVROLET CRUZE
230,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
CRAZYDOG72
MEMBER
I replaced the thermostat housing, and the oil cooler seal is deteriorated. Do I have to get a new gasket, or can I use RTV sealant?
Feb 24, 2024 at 9:08 AM
Experienced Mechanic
I believe you are referring to the oil cooler pipe. That is an O-Ring and needs to be replaced. If you use RTV, it will not last.
Take a look at the pic below. Is that what you are referring to?
See pic below.
Image (Click to enlarge)
Feb 24, 2024 at 12:24 PM
CRAZYDOG72
MEMBER
Yes, it is. Do you know the part number or the diameter of the o ring? I don’t want to take off the oil cooler pipe, if I don’t have to.
Feb 24, 2024 at 12:40 PM
CRAZYDOG72
MEMBER
I’m not sure which is the outlet (outer) side. I need the o ring that goes between the flange and the thermostat housing. Is this the right part?
Feb 24, 2024 at 10:58 PM
Yes, that appears to be correct. When you install it, first lubricate it with coolant. Once you do that, then you can install it.
Let me know how things turn out for you.
Feb 25, 2024 at 10:31 AM
Add image or video
Ask a new question
Engine won't start
Engine overheating
