Oil cooler
120,000 MILES • 1.8L • 4 CYL • TURBO • 2WD • AUTOMATIC
BOGDAN MARIAN
Hello.
At the car in the description I changed the plastic pipe that comes out of the engine and goes down to the oil cooler. Now I think I have problems with the oil cooler and the water doesn't go up more than 85 degrees and it's 15 degrees outside.
Is it the cooler that gives me oil in the expansion vessel or cylinder head gasket?
Thanks
Oct 29, 2020 at 11:09 PM
In short yes to both. It could be either one. Here is a guide that helps with this:
https://www.2carpros.com/articles/coolantantifreeze-in-the-engine-oil
The best and easiest way to test this is to test the head gasket and then replace the cooler if that passes.
Let's start with this and go from there. Thanks
Oct 30, 2020 at 3:57 AM
BOGDAN MARIAN
Before I had this oil leak in the expansion vessel, I changed the water pipe from the cylinder head to the cooler.
I suspect that when I changed the pipe from the oil cooler this cylinder head ran out of water. and when I turned on the engine it took a few minutes until the thermostat reopened for water to enter the cylinder head when the cylinder head gasket probably burned. Can it really burn so easily?
Nov 1, 2020 at 9:04 PM
It is unlikely. Even if there is coolant in the head it is still not moving until the thermostat opens so the coolant is going to heat up at the same rate. So if there is no coolant there, it won't get hotter faster. However, it is a simple test to follow the head gasket guide above. Let's just test it and go from there that way we know for sure. Thanks
Nov 2, 2020 at 10:31 AM
