Just bought this car it is a hatchback. It did not run got it for cheap. As I did an initial look over I pulled open air box and there is oil inside the hose to air box. I have researched a little bit an have come up with PCV valve failure possibly? What else or what could caused oil to be pushed through top end? It could have been overfilled I have no idea and cannot contact previous owner. It is enough oil in the air pieces that it is quite alarming. When I first turned the car over to see if it started it turned over slowly like battery was almost drained but there was no squeaking or noises so I do not think it spun a bearing. Just needing some help in figuring out the cause so I can fix it.
Jul 2, 2018 at 6:42 PM
