Engine oil mixed with radiator water
76,000 MILES • 1.4L • 4 CYL • 2WD
SURJITH
But water not go oil also no overheat, transmission fluid also good.
Nov 17, 2019 at 11:51 AM
  • 110,251 POSTS
Hi:
If this has an automatic transmission, confirm nothing is mixing with the ATF. Other than that, you most likely have a head gasket issue allowing oil to enter the cooling system. Most times, it is the opposite, but this can happen too.
Here is a link to check for a possible head gasket problem. Take a look through it and see if it helps.
Let me know what you find.
Nov 17, 2019 at 12:34 PM
