Oil change
45 MILES
LUNAGRACELY
What type of oil and oil filter do I use?
Nov 24, 2017 at 11:53 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Your owners manual says, "Use only engine oil meeting the dexos1™ specification of the proper SAE viscosity grade. Look for the dexos1 approved logo for GM approved
engine oil."
Here is a chart: http://www.centerforqa.com/dexos-brand2015/
Use SAE 5W-30 viscosity grade engine oil.
In an area of extreme cold, where the temperature falls below, an SAE 0W-30 oil may be used.
As far as the oil filter goes, you should go with an AC Delco.
Nov 25, 2017 at 12:08 AM
