Oil drain plug torque specs needed
103,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
SKOOTER24
  • 275 POSTS
I need the torque specs for the drain plug so I don’t over tighten them.
Jul 4, 2020 at 5:01 AM
STEVE W.
  • 15,418 POSTS
10 Ft. Lbs. With clean threads and a good gasket.
Jul 4, 2020 at 7:04 AM
SKOOTER24
  • 275 POSTS
Is there anyway to get the manual?
Jul 5, 2020 at 6:39 AM
STEVE W.
  • 15,418 POSTS
There are multiple ways to get the service information. Printed service books or online are both options, The benefit of the online information is that it generally has been corrected as errors are found, with the printed books you are sort of stuck with what is printed.
For the online information you can buy subscriptions for a single vehicle from both Alldata DIY and Mitchell1 . They offer monthly, yearly and longer. It is the same information that shops use.
AllData - http://www.alldatadiy.com/
Mitchell - https://www.eautorepair.net/marketing/default.asp
There is also the option of getting access to service information through Ford themselves, but the price is very high as the image shows.
For printed information it depends on what you wish to do, Chilton and Haynes both sell versions of the service information as books.
Jul 5, 2020 at 12:02 PM
SKOOTER24
  • 275 POSTS
Oh, okay. thank you very much.
Jul 5, 2020 at 1:06 PM
STEVE W.
  • 15,418 POSTS
You're welcome.
Jul 5, 2020 at 2:07 PM
