Oil change
227,700 MILES
BRANDON RIPTHURM VAUGHN
I normally use fully synthetic oil for oil changes. I forgot to mention fully synthetic yesterday and they put conventional. Will this cause problems?
Aug 4, 2018 at 7:47 AM
Good afternoon.
No, it will not but I would return and have it changed again. Once you use synthetic, you should stick with it to get the maximum advantage from the oil.
Aug 4, 2018 at 8:18 AM
