Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Nissan
Kicks
Engine
Oil Change
Oil change instructions needed
2019 NISSAN KICKS
18,000 MILES • 4 CYL • 2WD • AUTOMATIC
SKOOTER24
MEMBER
I need the instruction manual for changing oil for filter and drain plug.
Jul 21, 2020 at 3:44 PM
Experienced Mechanic
Here is a link that explains in general how to change motor oil and filter. Take a look through it and let me know if you have questions.
https://www.2carpros.com/articles/how-to-change-engine-oil-and-filter
Jul 21, 2020 at 3:56 PM
SKOOTER24
MEMBER
When changing oil it usually says after it contact the surface turn additional 3/4 this says when you feel a slight resistance.
Jul 22, 2020 at 8:39 AM
With a spin on filter, I always tighten it as much as I can by hand only. That is what I suggest.
Jul 22, 2020 at 9:59 AM
SKOOTER24
MEMBER
Is there a torque for the drain plug? and thanks for everything else.
Jul 22, 2020 at 12:57 PM
Here is the torque spec for the drain plug:
Drain plug tightening torque:
22 to 29 ft-lb (29 to 39 N·m)
I hope this helps.
Jul 22, 2020 at 1:15 PM
Add image or video
Ask a new question
