it's okay to use engine oil flushing/flusher when changing engine oil? thank you
Jan 27, 2019 at 12:59 AM
BMDOUBLE
✓Experienced Mechanic
There should be no need to use this on such a new vehicle unless the oil was never changed and is super sludgy.
Jan 27, 2019 at 1:17 AM
STEVE W.
With 13,500 miles this could be the first or second oil change if going by the light. Even then I wouldn't use a flush, just change the oil more often than the light says.
