After having the oil change the RPM's climb off the gauge and there is white smoke
88,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
RICHARD CASH
Recently had oil change at local garage, now when driven past 3,000 rpm's the revs climb off the gauge and plumes of white smoke.
Mar 10, 2020 at 7:10 PM
Good morning,
You will need to have the cooling system tested. White smoke is burning coolant and it could be a possible head gasket leaking issue.
https://www.2carpros.com/articles/white-smoke-or-steam-coming-from-the-exhaust-pipe
This has no connection to the oil change.
Mar 10, 2020 at 8:00 PM
