Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Volkswagen
Transporter
Exhaust
White Smoke
After having the oil change the RPM's climb off the gauge and there is white smoke
2015 VOLKSWAGEN TRANSPORTER
88,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
RICHARD CASH
MEMBER
1 POST
Recently had oil change at local garage, now when driven past 3,000 rpm's the revs climb off the gauge and plumes of white smoke.
Mar 10, 2020 at 7:10 PM
Experienced Mechanic
Good morning,
You will need to have the cooling system tested. White smoke is burning coolant and it could be a possible head gasket leaking issue.
https://www.2carpros.com/articles/white-smoke-or-steam-coming-from-the-exhaust-pipe
This has no connection to the oil change.
Mar 10, 2020 at 8:00 PM
Add image or video
Ask a new question
Engine won't start
Engine — Stall at Idle
