The fuel tank is held in place by two metal straps that attached to the frame.
You will have remove those straps along with all the fuel lines in order to remove the tank.
Also it is ideal to get the fuel drained before getting started.
I have included the fuel draining as well as complete replacement procedure for your reference (Look below).
https://www.youtube.com/c/2carpros/featured
Thank you
Images (Click to enlarge)
Sep 14, 2021 at 3:44 AM
