My car burns oil, should I add a thicker oil?
228,000 MILES • 1.8L • 4 CYL • 2WD • MANUAL
YAZIDAN
  • 141 POSTS
My car burns oil. do you recommend putting thicker oil as for example 5W40 instead of 5W30. thank you
Jan 27, 2024 at 10:58 PM
  • 55,721 POSTS
Using a thicker oil in a car that's burning oil is a commonly suggested remedy. Have you changed out the PCV valve because when the valve sticks open it can cause the engine to burn oil, here is the location so you can check it out. Check out the images (below). Please let us know what happens.
Jan 28, 2024 at 3:22 AM
YAZIDAN
  • 141 POSTS
yes. I changed the PCV valve from the dealer. no improvement.
Jan 28, 2024 at 7:06 AM
  • 55,721 POSTS
You might want to try a bottle of Lucas oil stabilizer and of course a thicker oil.
Jan 29, 2024 at 2:08 AM
YAZIDAN
  • 141 POSTS
So, can I put 5W40 instead of 5W30? However, 5w40 comes only synthetic. There is no synthetic blend. Is it okay to put synthetic? What do you recommend?
Jan 30, 2024 at 12:35 AM
  • 55,721 POSTS
synthetic oil tends to burn through engine a little more rapidly. I would try 10/40 racing engine oil. This oil tends to stay in engines longer.
Jan 30, 2024 at 2:21 AM
YAZIDAN
  • 141 POSTS
Sorry I forgot to ask. My car has a VVTI engine. is it safe to use thicker oil on these engines?
Feb 3, 2024 at 10:56 PM
  • 55,721 POSTS
At 228,000 the engine tolerances are extended so it should be okay.
Feb 5, 2024 at 2:33 AM
