Can I switch to synthetic blend oil?
2007 TOYOTA COROLLA
235,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
YAZIDAN
  • 141 POSTS
i use conventional oil in my car and do oil changes every 3,000 miles. My car does not burn oil. However, conventional oil is starting to be hard to find. can I switch to synthetic blend is there a risk that the car will start to leak oil aka main seal and others and will start to burn oil.
Thank you
May 7, 2023 at 7:55 AM
  • 55,433 POSTS
Switching from conventional oil to a synthetic blend oil should not cause any issues with oil leaks or oil consumption, as long as the oil meets the manufacturer's specifications for your vehicle. Here is the engine oil weight recommended:
Fluid Types
New standard for engine oil, GF-4. See TSB EG018-06 032906 for additional information.
Engine Oil Type
GRADE .................... API grade SL Energy-Conserving or ILSAC multigrade engine oil
VISCOSITY .................... SAE 5W-30
Capacities
*Engine Oil Capacity (drain and refill) .................... L (qt., Imp. qt.)
With filter: .................... 4.2 (4.4, 3.7)
Without filter: .................... 4.0 (4.2, 3.5)
Use 2CarPros anytime, we are here to help. Please tell a friend.
May 8, 2023 at 4:26 AM
YAZIDAN
  • 141 POSTS
is it okay if I use higher than that as for example : synthetic blend ILSAC GF-6A .API SP .5w30
May 8, 2023 at 10:13 AM
  • 55,433 POSTS
Yes, that should be okay.
May 10, 2023 at 3:47 AM
