Oil keeps seemingly disappearing out of the engine
2013 NISSAN JUKE
123,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
TRO2017
I replaced the oil about 3,000 miles ago and I just had to completely refill it. It was completely empty. A couple months ago I had the thermostats replaced because the engine kept overheating while idling.
Jan 7, 2019 at 10:17 AM
  • 110,244 POSTS
Oil consumption is most often the result of a leak. Other things such as burning in the combustion chamber can also do it.
Here is a link that helps locate and check for leaks. It shows the most common places leaks occur.
https://www.2carpros.com/articles/engine-is-leaking-oil
If the engine oil is burning in the engine, most times you will see blue smoke from the exhaust. So, pay attention to that.
See if you can find leaks or if you notice smoke, and let me know what you find.
Jan 7, 2019 at 11:09 AM
