Oil bubbles and spits out every time i take cap off
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
ROBERTS5538
Where i put oil in at it bubbles and spits out every time i take cap off. Pull dipstick out and it has some at tip then the next time it has none on stick. Two days ago i put little over half a quart.
Feb 1, 2018 at 9:33 AM
  • 31,937 POSTS
are you running the engine with the cap off? if so it will spry oil. i would do a full oil change with a filter and check oil consumption after 1,000 km's please let me know how much it uses and if there is any external leaks that need fixing first.
Feb 1, 2018 at 4:32 PM
Good morning.
Are you installing it with the engine running?
