Oil type
200,000 MILES • 6 CYL • MANUAL
ALFREDORTEGA
Can I use Slick 50 because of the high mileage?
Can I use synthetic oil?
Mar 17, 2019 at 8:18 AM
  • 110,248 POSTS
Welcome to 2CarPros.
Slick 50 is something I haven't heard in years. Can you use it, sure, but that won't eliminate an oil consumption issue. As far as a full synthetic, often times that can actually cause more of a problems due the the molecular structure of the product.
Can you tell me exactly what is happening? Is there a leak? Do you see blue smoke from the exhaust? How many miles are driven before the engine uses a quart of oil?
Mar 17, 2019 at 1:08 PM
ALFREDORTEGA
No, I am not experiencing any problems. I just acquired the vehicle and I want to prevent or avoid any problems, so I wanted to ensure I'm using the right products.
Mar 18, 2019 at 1:14 AM
  • 110,248 POSTS
Welcome back:
I understand. The most important thing you can do to extend the engine's life is to make sure you follow the manufacturer's maintenance schedule. Also, select the oil's viscosity based on ambient temperatures and how the vehicle will be used. If you look in the owner's manual, it will guide you to what is recommended. Also, always use a quality oil filter.
Mar 18, 2019 at 10:22 AM
