OEM 12V socket pigtail
180,000 MILES • 4 CYL • 4WD • AUTOMATIC
OREGONLOVECAMP
  • 5 POSTS
I need to replace My OEM 12V socket pigtail...
The red wire was broken and now I can't seem to find a good replacement part. please help.
Oct 25, 2019 at 12:10 PM
  • 110,248 POSTS
Welcome to 2CarPros.
Where was the wire broken? Is it something that could be repaired? As far as a replacement part, if you want the exact same thing, you will need to check a dealer, but chances are they are obsolete. At that point, your best bet would be to check salvage yards.
If you can, take a pic of where the wire broke and upload it for me to see. I'll let you know if it is something that can be fixed.
Oct 26, 2019 at 3:11 PM
OREGONLOVECAMP
  • 5 POSTS
This is the thing I need. I was wrong, it's the wire that was broken.
Oct 27, 2019 at 7:57 AM
OREGONLOVECAMP
  • 5 POSTS
This is the one, in my other 1993 Accord, it's working and I actually use this car now, or I would just swap it.
Oct 27, 2019 at 7:59 AM
OREGONLOVECAMP
  • 5 POSTS
This is the one, in My Other 1993 Accord, it's working and I actually use this car now, or I would just swap it.
Oct 27, 2019 at 8:00 AM
  • 110,248 POSTS
Is the wire broken at the plug? Are you able to cut it and use (and don't laugh) a butt joint connector to repair the wire?
Oct 27, 2019 at 2:26 PM
