Odometer and trip meter no longer work
48,500 MILES • V6 • 2WD • AUTOMATIC
SCOTT14
I have a low mileage on my G20 Sportvan.
The odometer and trip meter recently stopped working.
I have replaced the VSS which has not fixed the problem.
Is there a separate fuse in-line with the VSS and odometer that might be the issue?
Or is the next step to replace the dash/gauge panel? Thanks.
Mar 8, 2019 at 2:54 AM
Good evening,
Is the check engine light on?
If it is, chances are there is no signal from the VSS. Also, it would affect the shifting of the transmission.
If it is not, then yes, the cluster is the issue.
Mar 8, 2019 at 9:36 AM
SCOTT14
No check engine light and the van shifts fine. now to find a gauge cluster.
Thanks for your response.
Mar 8, 2019 at 9:50 AM
You are welcome.
Glad to help.
Mar 8, 2019 at 9:51 AM
