Odometer manipulation, is it possible to alter the actual mileage?
106,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
COLINPEDDIE000
Is it possible to alter the actual mileage by means of some type of equipment to advance or retard the odometer reading of the vehicle listed above?
Apr 2, 2023 at 8:33 PM
BRENDON S
  • 653 POSTS
Good morning, COLINPEDDIE000,
I unfortunately don't have any information on your vehicle as we are based in the U.S. and your vehicle is made in Chesire, England, United Kingdom.
You may be able to use a scan tool, but I am unsure as I have never tried doing it myself, we always had them sent out when a cluster was replaced. If you replaced the cluster and need it programmed to the correct mileage the parts department at the dealer can send it out and get it re-programmed. If you bought a vehicle and you suspect it has been rolled back then you can look at its service records or signs of wear that wouldn't coincide with the mileage, like arm rest, steering grip, things like that.
Here is an article that might be helpful:
https://www.2carpros.com/articles/how-an-odometer-works
Here is another article you may find helpful:
https://sanedriver.com/change-odometer-reading/
Thank you,
Brendon
Apr 2, 2023 at 10:08 PM
COLINPEDDIE000
I'll go directly to the point, i took my car to a garage and my car has gained 1,000 miles, they could not have driven that mileage in the 24 hours they had it, so I'm asking is there a way to advance a digital odometer, it's a Vauxhall Astra.
Apr 2, 2023 at 11:10 PM
BRENDON S
  • 653 POSTS
Yes, it is possible. You can go right on eBay and buy a tool.
Thank you,
Brendon
Apr 2, 2023 at 11:28 PM
  • 55,721 POSTS
Chances are they drove the car on a trip, how long did they have it?
Apr 3, 2023 at 7:28 AM
