I boosted another car with my car battery. Know the odometer numbers stay on and want to go off.
Aug 8, 2023 at 6:56 AM
STEVE W.
✓Experienced Mechanic
The description sounds like it could be a simple glitch. First thing I would try would be to disconnect the battery in your vehicle, clean the battery cables at both ends and re-install and see if a forced reset restores proper function. If it does great if not return and let us know. It's possible that it damaged the cluster but not as likely as the above.
