Speedometer not working
141,350 MILES • 1.6L • 4 CYL • 4WD • AUTOMATIC
KIKKO
How fast I'm driving is not moving.
Feb 10, 2020 at 10:00 PM
BMDOUBLE
  • 1,139 POSTS
The most common failure item is the vehicle speed sensor, but to start diagnosing this properly you will need to retrieve codes from the power-train control module and the instrument cluster module, then go from there.
Feb 10, 2020 at 11:40 PM
  • 55,770 POSTS
Here is how you get he codes to confirm the failure. The output speed sensor is "A" on the diagrams.
Feb 12, 2020 at 1:59 AM
