Odd Knock turn the wheel to reverse back?
167,000 MILES • 1.6L • MANUAL
MYFATHERSSON
  • 29 POSTS
Hi
I have a problem with my focus estate/station wagon.
When driving normally, no out of the ordinary sounds. If I pull forwards and the turn the wheel to reverse back, I get a single knock. If I am travelling forward and need to turn the wheel to full lock, I get a single knock.
I have checked ball joints, drop links, and drive shafts but I cannot find anything loose or worn.
Could someone suggest what else I could look at that might cause this?
Many thanks
Kevin
May 10, 2026 at 8:21 AM
  • 55,770 POSTS
Hello Kevin,
I have seen the CV axle wear and cause a pop noise but I would check the sway bar links and control arm bushing as well. I would also look is the front strut top mounts/bearings. If these lock up they will pop. You will need a flashlight and to raise the car up to check these, please go over this video to help.
https://www.youtube.com/watch?v=xLFn_bMkZc0
1. Steering rack mounting bolts/bushings — rack movement can cause a single knock when steering load changes.
2. Inner tie rods — sometimes they knock only under steering load and do not feel obvious during a basic shake test.
3. Subframe bolts/bushings — a slightly shifting subframe can make one knock when loading/unloading the front suspension.
4. Brake caliper bolts/pads — loose caliper hardware or pads shifting in the bracket can make a single clunk during direction changes.
5. Coil spring ends — check for a broken lower coil or spring not seated correctly in the perch.
6. CV axle outer joints — even if they feel tight, a worn outer CV can knock at full lock, though it usually clicks repeatedly rather than making one single knock.
Here is a guide to help as well
https://www.2carpros.com/articles/popping-noise/
Please upload a short video in your response of the problem, so I can see what's going on .
May 11, 2026 at 10:06 AM
