I've had an odd issue with my car lately with it's idle, when I first start it idles fine, when I go to back out in the mornings as soon as I turn the wheel the idle drops down to almost stalling, but doesn't stall, soon as I give it gas though it's fine. It does, however run fine while driving with no problems.
I've also had a few instances where the idle would get a little rough at a stop sign or red light, but lately it seems to happen more-so when I turn the wheel. So far it just seems intermittent, but when it does, if I give it a small rev it seems to fix itself, or if I put it back in N it goes away as well.
I had a CEL light for awhile, and just recently had some vacuum leaks fixed, and the CEL no longer comes on, so I don't think that is an issue, unless they possibly missed a leak. Is it possible that the IAC could be going bad at this point, or maybe something to do with the steering pump?
Any suggestions you have would be greatly appreciated.
Jan 2, 2015 at 9:54 AM
