OCCASIONALLY DIES ABRUPTLY
90,000 MILES • 2.3L • 6 CYL • FWD • AUTOMATIC
GERALD COLVIN
car runs smoothly but dies abruptly when idling or slowing down to stop.
Mar 23, 2017 at 4:06 AM
HMAC300
  • 48,601 POSTS
try cleaning throttle plate on both sides and iac hole with choke cleaner also check for vacuum leaks like hoses broken or cracked as well as duct work having holes between air cleaner and throttle. finally check fuel pressure with a gauge auto parts rent it. should be 41-47 psi minimum key on only with no drop within 5 minutes
Mar 23, 2017 at 5:35 AM
