Occasional stalling at low speeds?
136,500 MILES • 4.0L • V6 • AUTOMATIC
BUSINESSFRED
  • 96 POSTS
My 2010 V6 Mustang occasionally stalls at low speeds and when stopped in traffic.
The first occurrence triggered a Ho2s DTC Code , replaced that with a new denso sensor but the issue persisted .
The second occurrence was at a drive thru the car stalled multiple times I had to rev it and throw it into drive to get it moving it was driving in limp mode and gave a P0401 DTC Code for the EGR
I Cleaned the mass air flow , DPFE , and throttle body it improved but remained persistent again.
Since then I've replaced the spark plugs for new motorcraft plugs and it improved again slightly.
Any trouble shooting recommendations , the p0401 didnt come back after resetting and cleaning the MAF and Throttle Body as well as the DPFE sensor.
But if its a suspect I can also replace or clean it .
Feb 7, 2026 at 4:18 PM
  • 55,710 POSTS
To me is sounds like you have a vacuum leak, I would check the PCV line which failures are common. Here is a video to help you check for leaks.
https://www.youtube.com/watch?v=LRKWV4Are5c
Also, here is a guide to go over as well
https://www.2carpros.com/articles/stall-at-idle
If the EGR valve is leaking it will cause this issue as well, here is a video to help test it.
https://www.youtube.com/watch?v=DqUCbbKdWf4
Clear the codes once everything has been repaired, checked and let me know what happens. Ken
Feb 8, 2026 at 1:55 AM
