OBDII keeps giving communication error
DAMIEN8
Using an OBDII i keep getting a communication error although it is connected properly. is there another diagnostic code reader i should be using? Ute sometimes doesnt want to start. Fuel pressure and spark is fine. If i leave ignition on until the engine light goes out the car will start.
Apr 30, 2013 at 12:01 PM
KHLOW2008
  • 41,812 POSTS
Some code readers are not compatible and would not read so you might need to try any model. You can try bridging the # 1 and # 4 terminal of the DLC and turning the ignition on to check if the MIL flashes the codes. If yes, you can read the flash code and for a more accurate code, get another reader/scan tool to check.
Apr 30, 2013 at 12:45 PM
JAGGERJACK06
  • 14 POSTS
Furthermore on what the above user has said the early mitsubishi vehicle that run OBDII use a certain type of ISO protocol, so if you are to buy another scantool, ensure that it supports the correct ISO protocols
May 21, 2013 at 11:34 AM
KHLOW2008
  • 41,812 POSTS
That was what I encountered previously. My normal code reader could not communicate with the system.
May 21, 2013 at 10:07 PM
