OBD2 Scanner recommendation
116,000 MILES • 2.0L • V6 • TURBO • 4WD • AUTOMATIC
IMAGING
  • 151 POSTS
What do you recommend for a scanner that can access live data for like the graph for 02 sensors, battery life, coils, spark plugs, air bags, fuel trim, etc., and that can program keys for the SAAB? And, since I have other makes and models of vehicles, to be compatible with them as well.
Oct 10, 2021 at 8:33 AM
SQM
  • 6,383 POSTS
Depending on how much you want to spend there are many good scanners in the market.
For a decent entry level scanner Foxwell NT301 is a very good one at less than $70.00. This is a favorite one for most DIYers. Covers typical live data for all the functions. Can't go wrong for the price.
For bit more money you can get a Innova 5610 cost around $330.00. This will cover just about anything you want to scan from ABS to transmission to SRS and provides detailed data. This one sees quite a bit of use in the shop environment.
Both of these can do all OBDII vehicles.
Any questions, please let me know.
https://www.2carpros.com/trouble_codes/obd2
Oct 10, 2021 at 10:22 AM
IMAGING
  • 151 POSTS
with the Foxwell NT301, can it do live data of let's say the health of the 02 sensors and can it program keys like of a SAAB.
Oct 11, 2021 at 2:04 AM
SQM
  • 6,383 POSTS
I don't believe that will program keys. Typically, any scanner with key programming function that can cover multi brand runs close to $1,000.00 or more.
Oct 11, 2021 at 1:14 PM
IMAGING
  • 151 POSTS
My vehicle had a check engine light on. It goes on and off sporadically. What could this mean?
Oct 11, 2021 at 11:36 PM
SQM
  • 6,383 POSTS
It sounds like an intermittent issue that in certain condition exists. Best step would be to get it scanned while the light is illuminated. The code(s) can help determine what could be the issue.
Oct 12, 2021 at 2:39 AM
Hey Imaging. Thanks for getting a new post started for this. Glad SQM helped you out on this. He is quickly becoming one of our best.
If you need more help on the check engine light, let's get another one started for that as well.
Keep in mind this is not only here to help you but others that visit in the future and have the same issue as you do.
So, they won't find specific check engine questions under this heading.
I know this is not convenient but you have good questions so we want to make sure all can find them and benefit from your solutions.
Thanks again.
Oct 12, 2021 at 9:01 AM
IMAGING
  • 151 POSTS
okay. Perfect. Will start a new post for the check engine light. And. thanks for all your help in everything. You have been very helpful.
Oct 12, 2021 at 8:21 PM
SQM
  • 6,383 POSTS
Thank you very much.
Oct 13, 2021 at 1:11 AM
