Obd2 port
150,000 MILES • 1.9L • 4 CYL • 2WD • AUTOMATIC
GENE BAILEY
Obd2 power but will not connect. I have a will crank but no start.
Nov 17, 2018 at 3:54 AM
Good afternoon.
What kind of scan tool are you using?
Does the check engine light work?
Did you check all the fuses for power on both sides?
Nov 17, 2018 at 4:04 AM
GENE BAILEY
I have a tech 2 and a smaller Mac the obd2 port has power and ground but will not connect. Yes and relays. I can jump across the fuel pump relay to get it on it has 55# pressure. But no spark or fuel when cranking through, good compression too.
Nov 17, 2018 at 4:29 AM
Okay, check for powers to the PCM. Make sure you have ignition and battery power.
I attached wire diagrams for you to view of the fuel system as well as the ignition system.
Nov 17, 2018 at 5:45 AM
GENE BAILEY
Okay, thanks so much.
Nov 17, 2018 at 6:34 AM
You are welcome.
Always glad to help.
Nov 17, 2018 at 6:39 AM
