OBD2 not connecting
170,000 MILES • 1.9L • 6 CYL • TURBO • 2WD • MANUAL
DAVE321123
My check engine light is on but bag com cannot find the ECU? Anyone have any ideas? The OBD socket is clean and I have checked all the internal fuses.
Nov 26, 2018 at 4:55 AM
  • 110,248 POSTS
If you confirmed power and ground to the DLC, then there has to either be an issue with the ECM or the wiring to it. From the DLC (pin 7 ) there is a green/red wire that runs to the comfort control module, ECM, and TCM. I have attached a schematic for you to see. Chances are there is a problem with one of the splices.
By the way, I had to break the schematic in two because of size.
See if this helps and let me know.
Nov 26, 2018 at 9:53 AM
