OBD2 - connection, unable to connect to the ECU?
200,000 MILES • 2.4L • 6 CYL • TURBO • 4WD • MANUAL
DOMINIKMATEJKA
If you connect MUT-II original Mitsubishi diagnostics to je port, it starts to blink out the codes to dashboard, but we are unable to connect to the ECU.
Jul 21, 2022 at 11:21 PM
  • 55,721 POSTS
Can you connect with a regular scanner? Your MUT-II original might be bad, also check the fuse #11 the Multipurpose behind the left side of dash fuse panel. here is a guide and the fuse location in the diagrams below:
Here are the wiring diagrams for the ALDL connector so you can see how it works. Check out the diagrams (below). Please let us know what happens.
Jul 23, 2022 at 2:50 AM
