OBD1 connector
185,000 MILES • 4.0L • 6 CYL • 2WD • MANUAL
HAMMONSM
I cannot find where to connect my meter on the truck listed above.
Jul 26, 2020 at 3:38 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
If you're looking for the OBD port to connect a scanner or code reader these are the 2 possible locations.If your truck has OBD1 it's located under the hood on left hand side on top of the fender well.If your truck has the newer style EECLL or otherwise known as OBD2 it is on the lower left of the dash about knee level.
https://www.2carpros.com/articles/ford-lincoln-mercury-obd1-1995-and-earlier-diagnostic-trouble-code-definition-and-retrieval
I've attached a picture of both below.Hope this helps and thanks again for using 2CarPros.
Jul 28, 2020 at 1:51 PM
HAMMONSM
Danny,
Thank you very much, I found it. You are a very nice person.
Thank you, Mike Hammons
Jul 29, 2020 at 10:43 AM
  • 55,781 POSTS
DANNY L is one of our best! Use 2CarPros anytime, we are here to help. Please tell a friend.
Jul 29, 2020 at 10:44 AM
DANNY L
  • 5,648 POSTS
You're welcome!
Thanks Mike. Please use our site again when needed. Also, If you use the diagnostic port to check for codes we can help with that too if codes are found.Thanks again for using 2CarPros.
Danny-
Jul 29, 2020 at 11:02 AM
HAMMONSM
The temperature gauge is normal. I drive it around the block, until I started up a hill and give more gusto go up the hill and it went to hot to the to the top. Now when I got back and open raised the hood it was not hot.
Aug 1, 2020 at 8:25 AM
DANNY L
  • 5,648 POSTS
Hello again.
So are you saying you might be having an overheating or running hot temperature condition?Let me know and we'll go from there.Thanks again for using 2CarPros.
Danny-
Aug 2, 2020 at 2:36 PM
HAMMONSM
The temperature gauge is moving to hot but motor is not.
Aug 3, 2020 at 4:12 AM
DANNY L
  • 5,648 POSTS
Hello again.
Since your truck you say is running at normal temperature but the gauge shows hot it's possible the ect- engine control temperature sensor is faulty,defective, or showing an incorrect reading.Here are a few tutorials to view for its description and replacement:
https://www.2carpros.com/articles/how-a-coolant-temperature-sensor-works
https://www.2carpros.com/articles/symptoms-of-a-bad-coolant-temperature-sensor
https://www.2carpros.com/articles/coolant-temperature-sensor-cts-replacement
I've attached pictures below of its location and steps on how to replace.Hope this helps and keep us updated on this issue.Thanks again for using 2CarPros.
Danny-
Aug 3, 2020 at 4:34 PM
HAMMONSM
Danny,
Thank you very much that what it was and now runs good. Thanks and god bless.
Aug 7, 2020 at 8:42 AM
  • 55,781 POSTS
DANNY L is one of our best! Nice work, we are here to help, please use 2CarPros anytime.
Aug 8, 2020 at 5:02 AM
DANNY L
  • 5,648 POSTS
You're welcome!
Thanks again for using 2CarPros and hope you use our site again in the future.
Danny-
Aug 12, 2020 at 1:05 PM
