OBD port has no power and the power tailgate will not lift
90,000 MILES • 1.6L • TURBO • 4WD • AUTOMATIC
DARREN737
I have no power when I try to plug in my obd reader and it will not communicate also my power tailgate will not open with any of the buttons. My cigarette socket has power and I don’t see any blow fuses. Can you give me some idea where’s to look thanks. Also when I plug my scanners in I get a beep on it then the display dies. Any help would be appreciated thanks
Apr 21, 2026 at 12:36 PM
  • 55,542 POSTS
Can I ask if the lights come on the dash and do you have interior lights? If not I would remove the battery and have it load tested, if the battery is okay let check the fuse #16 in the fuse panel on the left side of the dash. The guide can help.
We must get the scanner to work to find out the codes, but like I say it sounds like the battery is no good, please let me know.
Apr 22, 2026 at 1:00 AM
