No power to the OBD port which fuse should I check?
220,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
COOPER2025
No power to the OBD port, wonder which fuse number I should check first.
Thanks
May 14, 2025 at 3:58 AM
AL514
  • 5,689 POSTS
Hello, power for the DLC (pin 16) comes from the LTR Fuse 53 20amp in the under-hood fuse block. I'll post a wiring diagram of the circuit as well.
May 14, 2025 at 6:22 AM
AL514
  • 5,689 POSTS
Here is the wiring diagrams for the Data link connector, notice power also goes to the I/P Accessory power outlet, so I would make sure nothing fell into the power outlet and shorted it out, blowing the fuse.
May 14, 2025 at 6:32 AM
