OBD-II code P0116
2013 TOYOTA SIENNA
69,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
TED ANTAL
Air conditioner does not cool when car is at idle most of the time. Just blows ambient air. When I checked for error codes, I got P0116. Neither radiator fan is working except occasionally both fans start and then stop after a few seconds.
The other day I turned on the engine and AC and sat in a parking lot for about fifteen minutes and the AC worked fine. Then, when I started driving through the parking lot to leave the AC air coming from the front vents was ambient. When I got on the Interstate, the air was cold again.
At highway speeds air is cold.
Car starts and runs fine otherwise. No check engine light. Inside temp gauge is below 1/2 and car does not seem to overheat. I'm thinking I should replace the Engine Temperature Sensor to start.
Van is the XLE model.
May 18, 2019 at 6:20 AM
  • 110,240 POSTS
Welcome to 2carPros.
I think you are on the right track. The code is for the coolant temp sensor. For this code to set, there is no change in the reading from the sensor between a cold engine and a warm engine. With that, either you have a bad connection, damaged wire, or the sensor is bad.
Since this controls the fan operation, most likely it is causing the AC issue as well. The first two pictures I attached show location. I circled the sensor.
____________________________________________
Here is a link that explains in general how one is replaced:
https://www.2carpros.com/articles/coolant-temperature-sensor-cts-replacement
Here are the directions specific to your vehicle for replacement. They didn't make this easy.
Removal
Vehicle Powertrain Management Sensors and Switches - Powertrain Management Sensors and Switches - Computers and Control Systems Coolant Temperature Sensor/Switch (For Computer) Service and Repair Removal and Replacement Removal
REMOVAL
2GR-FE ENGINE CONTROL: ENGINE COOLANT TEMPERATURE SENSOR: REMOVAL; 2013 MY Sienna [08/2012 -]
1. REMOVE V-BANK COVER SUB-ASSEMBLY See: Engine > Removal and Replacement > Removal
2. REMOVE NO. 1 ENGINE UNDER COVER See: Exhaust Manifold > Removal and Replacement > Removal
3. DRAIN ENGINE COOLANT See: Coolant > Removal and Replacement > Replacement
4. REMOVE WINDSHIELD WIPER MOTOR AND LINK ASSEMBLY
See: Wiper Motor > Removal and Replacement > Removal
5. REMOVE FRONT OUTER COWL TOP PANEL SUB-ASSEMBLY See: Suspension Strut / Shock Absorber > Removal and Replacement > Removal
6. REMOVE AIR CLEANER INLET COVER ASSEMBLY SEAL See: Throttle Body > Removal and Replacement > Removal
7. REMOVE AIR CLEANER AND HOSE See: Throttle Body > Removal and Replacement > Removal
8. REMOVE ENGINE COOLANT TEMPERATURE SENSOR
(a)Disconnect the engine coolant temperature sensor connector.
pic 3
(b)Using a 19 mm deep socket wrench, remove the engine coolant temperature sensor.
pic 4
Text in Illustration
pic 5
(c)Remove the gasket from the sensor.
_______________________________________________________________________________
INSTALLATION
2GR-FE ENGINE CONTROL: ENGINE COOLANT TEMPERATURE SENSOR: INSTALLATION; 2013 MY Sienna [08/2012 -]
1. INSTALL ENGINE COOLANT TEMPERATURE SENSOR
(a)Install a new gasket onto the engine coolant temperature sensor.
pic 6
pic 7
(b)Using a 19 mm deep socket wrench, install the engine coolant temperature sensor.
Torque : 20 Nm (200 kgf-cm, 14 ft-lbf)
(c)Connect the engine coolant temperature sensor connector.
2. ADD ENGINE COOLANT See: Coolant > Removal and Replacement > Replacement
3. INSPECT FOR COOLANT LEAK See: Cooling System > Initial Inspection and Diagnostic Overview > On-Vehicle Inspection
4. INSTALL AIR CLEANER AND HOSE See: Throttle Body > Removal and Replacement > Installation
5. INSTALL AIR CLEANER INLET COVER ASSEMBLY SEAL See: Throttle Body > Removal and Replacement > Installation
6. INSTALL FRONT OUTER COWL TOP PANEL SUB-ASSEMBLY See: Suspension Strut / Shock Absorber > Removal and Replacement > Installation
7. INSTALL WINDSHIELD WIPER MOTOR AND LINK ASSEMBLY
See: Wiper Motor > Removal and Replacement > Installation
8. INSTALL NO. 1 ENGINE UNDER COVER See: Exhaust Manifold > Removal and Replacement > Installation
9. INSTALL V-BANK COVER SUB-ASSEMBLY See: Engine > Removal and Replacement > Installation
Let me know if this takes care of it. Also, if you need additional information for the removal process, let me know.
May 18, 2019 at 3:47 PM
TED ANTAL
Thanks Joe. Man, that's a lot of steps to just replace a sensor! Do you think there's a way to get to the the sensor without so much disassembly? I'm a little confused of its location, too. Is it on the lower right side of the engine, in front of the firewall? If I took it to a local mechanic, how many hours would the charge be?
Thanks again.
Ted
May 18, 2019 at 10:26 PM
TED ANTAL
Just checked the link you included and saw the repair price of $120.00 to $180.00. Thanks again.
May 18, 2019 at 10:40 PM
  • 110,240 POSTS
Welcome back:
Looking at the pictures, I see why it's confusing. One shows it in the rear of the engine and the other right rear the upper radiator hose. Take a look on your vehicle where the upper radiator hose connects to the engine to see if that is where it is. In the past, that is where I remember them being.
As far as parts and labor, take a look at the picture I attached. It shows part price (original equipment) and labor time.
Let me know if that helps.
May 19, 2019 at 10:41 AM
